How big is the radial and longitudinal dilatation of PT6A turbine?
If anybody know an approximate value for this engine dilatation, please give me a response. Thanks in advance.
Fernando
RE: How big is the radial and longitudinal dilatation of PT6A turbine?
Segnor Fernando,
PT6A, a turboprop engine (gas turbine), is a product of P&W Canada.  I suppose that they will supply you with this data and even some installation schemes if you propose them a new application (a potential new market).
Their web address is http://www.pwc.ca/
I almost forgot to thank you for your kindness. In fact, I was afraid about the solution chosen by my new colleagues (which are not engine aircraft engineers).
Meantime, I realised that their solution is good enough. I also receive a confirmation from P&WC that the dilatation is small and we will not have any problems with the engine installation (but they don't said nothing about the values). Anyway, this can be measured when we will do some tests.
Once again, thank you.
Fernando
