When pouring a Tremie slab..
  Does the weight of the water that the Tremie Slab is displacing keep the slab Level while pouring..????
RE: When pouring a Tremie slab..
Not appreciably... you are looking at the local differential in concrete height... as an example, you may have 40' of water on the concrete surface at one location and 41' of water adjacent to it... only a 1' differential.
Dik
Concrete slump, experienced workmanship, and monitoring keep the tremie pour level.
www.PeirceEngineering.com
