Vfd cable terminations / braiding, shielding, etc
Currently doing a small industrial job, installing cabling for ( 20 ) 5 hp motors. There seems to be a wide opinion of how the vfd cables should be terminated....braiding, shielding, etc Any advice would be appreciated ,or any links as well. Thx.
RE: Vfd cable terminations / braiding, shielding, etc
All of these are important to getting you the right answer.
The shield and the ground lead form a ground bond between the drive and motor ground forcing them to the same potential. This is important to avoid nuisance faulting on the drive.
