Bonding Nylon to Steel
Hi Guys
I was wondering if anybody knows of any industrial strength adhesives that would bond nylon to steel?
The application is a 2m long wear pad and bolts arent really ideal as the pad is difficult to access so need as much wear as possible.
The pad would be subject to high shear loads and salt spray conditions.
Any help would be appreciated
RE: Bonding Nylon to Steel
Nylon's chemical stability makes it hard to glue. Can you embed the stuff in a pocket somehow? Perhaps you can weld a barrier around it to keep it from sliding.
Have you searched Google?
We did use hot resorcinol as a nylon adhesive. the bad part is that I can find no good information on the process.
http://www.reltekllc.com/adhesives-for-nylon.html
nylon coated splines are fairly well proven
... Not that I've ever seen such a thing.
Mike Halloran
Pembroke Pines, FL, USA
http://www.crownplastics.com/
Ted
http://www
Mike
http://ww
You need to understand expansion of nylon in a wet environment before gluing, or screwing down wearstrips.
http://www.sdplastics.com/nylon.html
