Image Quality Problem
Is anyone having issues with the image quality slider with SW 2010 x64 sp4.0? i have it set towards the high side, and it looks good. but a lot of times if i roll back in the tree, and do some edits, the slider will fall all the way to minimum, and i have to constantly keep restoring it. My part templates are set with the slider where i want it. Thoughts? Thanks!
RE: Image Quality Problem
That should be your first place to look. The Second thing I would try is to turn software OpenGL on and see if the issue continues. If it does continue then its probably some sort of Video card/driver issue, even if you using the certified driver.
Cheers,
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum PoliciesBerry Plastics
Cad Admin\Design Engineer
www.scottjbaugh.com
i have a correct driver yes.
Maybe I have just been lucky
Jim Self
SW10 SP4.0
Dell Precision T7500
Win 7 64bit
6GB Ram
Quaddro FX 4800
dlplimited.com
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2010 SP 3.1
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
