Corrupted files?
Corrupted files?
All of a sudden we are getting files that will not open in NX5.
The Error is the following:
An invalid handle index was found reading an OM file: probable corruption.
Has anyone else had this happen? What could be causing this?
RE: Corrupted files?
What release of NX5 were the files created in and what release do you have?
Do you have all of the components if they are assembly parts? Linked geometry between files can cause some strange errors.
Ben Loosli
After the assembly is open (withy nothing there) go into the assembly navigation tree and open each component individually to see which component is causing the error.
