Air volume passing through a hole
What is the maximum volume of air that can pass through a 1 mm hole. The material through which the air is passing is stainless steel with a .25" wall thickness. I don't believe it is relevant but the air is being sucked through rather than pushed through the hole.
Can you point me to an online calculator for similar queries.
THX.
Dale
THX.
Dale
RE: Air volume passing through a hole
the "maximum" volume of air (or anything for that matter) that can pass through a hole (any size) is infinite.
however, in your case it is finite 'cause it's driven by the pressure differential. if you're after volume/second then you need the area (of the hole) and the speed of the air (A*V = m^3/sec).
speed depends on the pressure differential, delta P = 1/2*rho*V^2, where rho is the density of air, something like 1.2 kg/m^3 (make sure you have mass density).
the tricky part is the "coefficient of discharge" of the hole. google this, the engineer's toolbox link gives a table that may help. or the mcnallyinstitute link for "flow through an orifice" ... but be careful with the equations that are posted about, most of them deal with flow out of a bucket (flow is driven by the pressure head).
the ease of finding these links makes me wonder what googling you did on your own ??
Cheers
Greg Locock
The maximum flow of air through a hole will be fixed when it chokes. If I remember correctly the max pressure ratio is 1.8 for air. You can check this is any compressible flow text book.
The previous reply of p = 1/2 rho v^2 is strictly speaking for incompressible flow and is only really valid when mach no (M) < 0.3. Choking occurs when M = 1.
Hope this helps.
allan
If we could treat it as a simple nozzle then:
work out your pressure ratio, if its greater than 1.895, (simple ratio of gamma) then its choked. then;
Calc , static temp at the throat (M=1), do a search for isentropic flow equations , nasa site should pop up.
M =1 at the throat, and static temp gives you your velocity. (M= U/a , a = root , (gamma* R* Ts)
Calc static density at throat as well.
m dot = density* area * U
The calculation is the wrong way around for this particular problem, i.e. you give it a mass flow and it calculates the area but you should be able to work backwards. Next upgrade is to enable the user to switch this.
