Radius maching with short length ballnose EM
HI all
I am using 5axis horizontal machining ceneter (X,Y,Z,B,A) to cut a fillet arround the boss with short lenth ball nose endmill.In this case to avoid gouging on the part all 5 axis (X,Y,Z,B,A) should move am I rite.I tried with mult multiaxis variable contour and contour profile but I failed.
Can any one give an idea?
I attached a simple sample part file can you go through that.
file is in nx 7.5
thanks and regards
neeru
file is in nx 7.5
thanks and regards
neeru
RE: Radius maching with short length ballnose EM
Bill
HI Bill
you can fix Xo Yo Z0 A0 B0 at any where. Just I want use short lenth endmill
Thx and Regards
Bill
Bill
Thax Bill, I did with contour profile/streamline .
