angular dimension
angular dimension
is there a way to control the angular dimension from 0 to 360 degrees? (not to 180 deg)
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: angular dimension
Is this an actual dimension or a mate, and is it in a model sketch or drawing?
In either the Model or the Drawing, the angular dimension could be any one of 3 types, depending on how the dimension is dragged into position. Pick one line, then the other, then drag the dimension to control the type.
1) Acute (less than 90)
2) Obtuse (between 90 and 180)
3) Reflex (between 180 and 360)
So, I need to read into design table (excel) parametres for a mate - of course in assembly. Best would be to get value 0-360 deg, but understand that SW can do it 0-180 and further 180-0...
