Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I'm so glad I found this site... Now I can get some sleep, because my problem is solved..."
Geography
Exponential trendline fit in Excel using LINEST - fixing a variableHelpful Member!
GrahamSRowe (Bioengineer)
31 Dec 10 3:10
I know that you can use the following formulae in Excel to fit a curve using LINEST for the named ranges x and y:
Exponential Trendline
Equation: y = c *e ^(b * x)
c: =EXP(INDEX(LINEST(LN(y),x),1,2))
b: =INDEX(LINEST(LN(y),x),1)
My question is, if I want to fix c=1 can I simply use
b: =INDEX(LINEST(LN(y),x),1) and assume c=1?
Also would it be correct to use
r2: = INDEX(LINEST(LN(y),x),TRUE,TRUE),3)
in this case?
Thanks very much.
Helpful Member!  Brad1979 (Electrical)
10 Jan 11 15:36
The syntax for LINEST is:
LINEST(known_y's,known_x's,const,stats)
You can force the intercept to be 0 (which is equivalent to c=1) by setting const to FALSE.  So your equations should be:
c: =EXP(INDEX(LINEST(LN(y),x, FALSE),1,2))
b: =INDEX(LINEST(LN(y),x, FALSE),1)
This will cause b to be calculated assuming that c = 1.
10 Jan 11 15:47
Also,
this is correct in general but you'll want to change it to the following when you for c=1:
r2: = INDEX(LINEST(LN(y),x),false,TRUE),3)
Denial (Structural)
10 Jan 11 16:24
Note typo in Brad1979's last two formulae where "x)," should be "x,"
10 Jan 11 16:41
Yes, thank you for catching that.
BigInch (Petroleum)
17 Jan 11 8:33
I always find myself referring to this thread,
http://www.eng-tips.com/viewthread.cfm?qid=214997&page=1
Close Box
Join Eng-Tips® Today!
Join Us             Close
