Installation Engineer Wildfire 5.0
Hi all,, I have a question,for each answer, thanks in advance, I installed the software Pro Engineer 5.0. After running, I will always be warning labels, where it says:
" ERROR: Unable to launch Pro/Engineer beacuse no valid configuration (*.psf) files were found.Please run "ptcsetup" from your instalation "bin" directory and create a PTC Startup file. This is needed for Pro/Engineer to launch successfully."
Does anyone know how to solve it?
RE: Installation Engineer Wildfire 5.0
forum554: PTC: Pro/ENGINEER
