Pack n Go
Pack n Go
In my latest project I've been using the 'pack n go' feature quite often. I'm having one small issue. The file that I 'pack n go' is the top level assembly. My problem starts when I change the file names of the components within sub-assemblies of the top level. I've made the changes to the file names, but after I complete the 'pack n go' it only renames the files inserted at the top level. Any files that are components within the sub-assemblies remain as the previous file name and are not brought to the new save location.
Any ideas on why this might be happening??
RE: Pack n Go
Are the References/Where Used locations set correctly?
RE: Pack n Go
What version of SolidWorks are you on? What OS? And are you using a PDM client?
I can't replicate that issue when doing the same thing on...
SolidWorks 2010 sp4
Windows 7 x64
Jack Lapham
Engr Sys Admin
Dell M6400 Covet (24 Season 8, Ep 22)
Intel Core 2 Duo T9800, 2.93GHz, 1066MHZ 6M L2 Cache
8.0GB, DDR3-1066 SDRAM, 2 DIMM
1Gb nVIDIA Quadro FX 3700M (8.17.12.5896)
W7x64 | sw-01: 55.92
SolidWorks x64sp4 in PDMWxE
RE: Pack n Go
Jack,
Not to change the subject, just curious what is the photo above your signature?
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
RE: Pack n Go
I have gone back and replaced all the files, I'm just wondering why this would happen.
RE: Pack n Go
Do you mean you went to SolidWorks Explorer > Options > References/Where Used and added the folders involved?
