SHEAR WALLS IRREGULAR DISTRIBUTION
GENTLEMEN:
I AM DOING AN ETABS MODEL WITH ( SHEAR WALLS IRREGULAR DISTRIBUTION ) DUE TO ARCH, DESIGN.
A BIG ECCENTRICALLY VALUE BETWEEN CENTER OF RIGIDITY AND CENTER OF MASS IS RESULTED.
DO I HAVE TO CONSIDER THE ECCENTRICALLY VALUE WHILE CALCULATING SEISMIC FORCES ( BY AUTOMATIC SEISMIC FORCE  CALCULATION ) OR IT WILL BE CONSIDERED AUTOMATICALLY BY THE PROGARM?
RE: SHEAR WALLS IRREGULAR DISTRIBUTION
ETABS automatically calculates the additional torsional shears due to difference in CR and CM. I would define the diaphragm as semi-rigid to make sure proper in-plane diaphragm stiffness is accounted for.
would you explain in more details how etabs calculates the torsion due to eccenercity. do i have to identify any parameters to do that.
No, you don't have to do anything more than accurately modeling the locations/stiffness of the elements and the applied loads on the building.
Once the analysis is complete, you can see that the program has calculated a diaphragm center of rigidity and center of mass and the associated eccentricities.
GENTLEMEN:
I HAVE APPLIED SEISMIC LOADS ACCORDING TO UBC-97 ( AUTO LATERAL LOADS). WITH DIFFERENT ECCENERCITIES VALUES BY ADDING
AND/OR DELETING WALLS TO CHANGE THE POSITION of center  OF RIGIDITY.the results load values ( T ,Mx and My) are still the same. i think that we have to apply manually the eccentercity value at each floor.
would you advise once again
