pressure reservoir needed
I am going to use a 40mm bore short stroke double acting cylinder at high speeds. I would use an air mainline in a lab at 6 bar .. or alternatively a portable compressor.
Someone told me that I might need a reservoir between the 5/2 valve and the mainline/compressor. Do I? I would have though a compressor or an airline in a lab would have provided a suitably high flow rate and stable pressure air supply...
What do you think?
F
What do you think?
F
RE: pressure reservoir needed
