Modeling an obstacle in HEC-RAS
Upstream of a major bridge, a fender system was constructed to prevent damage to the bridge piers by the accidental barge collision. The system consists of individual cylinder shaped structure constructed of sheet piles driven to the river bed in a circular shape (30' diameter). They are called DOLPHIN, and extend from the river bed to approx. 8' above 100-yr W.S.E., and there are 4 of these giant structures guarding the piers. My question is:
What is appropriate way to model this kind of obstacles in HEC-RAS? One suggested modifying pertaining cross sections to create a section that represent these structures. I did that and after running the model the W.S.E. dropped, I suppose due to reduced x-sec area. Another suggestion was to model the obstacles as piers. I did that too, and the result was that the W.S.E., was raised. So what is the correct way to model this?
I thank you in advance for any suggestion you can provide.
RE: Modeling an obstacle in HEC-RAS
Remember that HEC-RAS is a one-dimensional model. It might be better to use a two-dimensional model in this case.
If you post an image we could be more helpful.
Thanks again
From this (h
Please share your opinion.
Thanks again
TTFN
Chinese prisoner wins Nobel Peace Prize
