Web Openings & Moment Connections
Does anyone know of any guidelines, buiding code requirements, AISC specs or AISC Design Guide #2 recommendations against putting web openings in beams/girders with moment connections?
These beams are part of the lateral load resisting system and they have moment connections.
RE: Web Openings & Moment Connections
If you cannot move it away from the moment connection, then you will probably have to have a much stronger beam than would have otherwise been required.
