Do high chlorine levels interfer with FerroVer reagent?
An odd situation, but would a chlorine level of 20-30 mg/l interfer or give a false iron reading from the FerroVer reagent?
RE: Do high chlorine levels interfer with FerroVer reagent?
The chlorine will probably interfere with the reading because the chlorine will oxidize the iron and make the sample turbid. You would have to add more reagent to make the iron soluble again.
See the statement from Hach:
"For turbid samples, treat the blank with one 0.1-g scoop of RoVer Rust Remover. Swirl to mix."
