1045 Normalized Round Bar Charpy Problem
Hello everyone and thank you for reviewing my post/question and offering your expert opinions.
Here is the trouble: I have a project I am working on that calls out for the following: CAN/CSA G40.21 Grade 300W OR AISI 1045 in the Normalized Condition. Needs to conform to min yield of 350MPa and tensile of 480MPa. 15% min elongation and cat. 3 Charpy Impact Testing with Min. absorbed energy of 27 Joules.
I have 3", 4.75", 5", 6", 7" and 10" round bar in a normalized 1045 that has everything in line EXCEPT the charpy values which are reading between 11 and 15 Joules average. I asked my customer to review his specification of 27 Joules but I am so far off something has to be missing from his spec.?
Any advice on how to increase the Joules? I do not see any way I can get to a 27 min. Joules with this steel no matter what process I put it through. There has to be a problem with the spec.?
Thank you.
Thank you.
RE: 1045 Normalized Round Bar Charpy Problem
What is your minimum test temperature for CVN impact? Why is the 1045 steel being permitted when CAN/CSA G40.21 Grade 300W is specified? You can look at tempering after normalization to see if you can improve the impact numbers, but I doubt it as well.
They gave us an option to use "either/or" in the case of the grade 300W or 1045. The 1045 was more readily available and after talking with our lab personnel, we believed the 27 Joules would not have been a problem.
That is clearly not the case.
What are your actual yield/tensile/elongation values?
Because of the 0.45 mass percent carbon content, you are going to need to have an alternate heat treatment other than normalization to achieve this minimum impact value at
-20 deg F.
Also consider 1045 has very limited hardenability, and as such larger diameter grades will be even more diffucult to achieve this minimum impact value using only normalization heat treatment.
METENGR - testing was -20 C, I assume that will make a difference?
Plymouth Tube
27J or 20 ft-lb for -20C is difficult for a normalized structure, but fairly easy for a Q&T steel with appropriate chemistry. Current chemistry seems lean for Q&T, especially for the large diameters.
One suggestion to your current double normalizing plan is that you may want to check the grain size right now. if it is already fine, I suspect how much benefit you can get?
Moving forward, to avoid these issues, what grade of round bar steel would best perform to hit the 27Joules minimum with just a normalize - is any?
Again the customer clearly specified either:
or
AISI 1045 in the Normalized Condition - clearly this is not the right option to keep costs down.
Being from the states I am unfamiliar with the 300W spec. but the customer called today and asked the next batch try to come from 44W as well. I don't want to keep tripping over this and spending too much time and money if we can not get it right.
In my mind, the requirement is high for a normalized steel, unless you can get extremely fine grain structure. It is not the chemistry, it is the normalized structure which has high DBTT, not suitable for low temperature usage.
