ASTM A516 gr.70 in place of gr.60
can someone please tell me about the replacement ASTM A516 gr.70 in place of gr.60? service is Caustic Soda.
Thanks in Advance
Thanks in Advance
RE: ASTM A516 gr.70 in place of gr.60
Min Yield = 32000 psi
Tensile Strength = 60000 to 80000 psi
% Carbon (Max) = 0.21 to 0.27
ASTM A516 Gr. 70:
Min Yield = 38000 psi
Tensile Strength = 70000 to 90000 psi
% Carbon (Max) = 0.27 to 0.31
Will the slight increase in % Carbon lead to a problem with the caustic soda? I wouldn't think so because you're going to be surface protecting the steel to begin with.
h
S.
Corrosion & Rust Prevention Control
