MATLAB, thermal simulation
I'm currently studying FEA/CFD and BEM for thermal simulation of custom dies within custom package mounted on custom PCB with encapsulate material (epoxy). I getting familar with CFD concept which seem overkill from ANSYS IcePack (too expensive) but exploring BEM technology from E3D in france (via Vishay).
I have access to MATLAB from other company to try it out for thermal modelling (ie BEM).
I never use MATLAB before, what the best step to learn it (quickly), has anyone use MATLAB for thermal simulation under BEM (or CFD or FEA). I also like to hear their experience and limitation.
Is MATLAB is a right tool for this job?, any reason why I should not consider it?
RE: MATLAB, thermal simulation
If there is a pre-written toolbox, then there may be a chance. That pre-written toolbox will need to be able to swallow some sort of CAD model of your designs, otherwise, good luck with that too.
There are, of course, lumped model approximations that could be coded into MATLAB, ala, "Thermal Computations for Electronic Equipment," but, that'll require quite a bit of fiddling to determine the correct degree of lumpiness to apply.
TTFN
Chinese prisoner wins Nobel Peace Prize
It's perfectly capable of programming anything you can think of and have the skills to do. I have done some FEA from scratch using Matlab. Lots of work.
IRstuff has all the perfect points.
Fe
(2B)+(2B)' ?
TTFN
Has it done before?
Where can I find the sample files, representing PCB, ICs, etc.
TTFN
I although prefer Matlab syntax. I used to like Fortran the most.
Fe
Fe
http://w
TTFN
Good on ya,
Fe
Fe
Not to say that MATLAB can't handle FEA - it can. I've actually written an 2D FEA in MATLAB back in college. It just seems like it would be more efficient to use existing tools.
Cheers
Greg Locock
