Does teamcenter allow you to work locally?
When checking out parts in Teamcenter are parts copied to your local hard drive for modification and then saved back to the server at check-in? Or ... are you still working over the network?
It has been suggested to me that many pdm packages copy files to the local hard drive and as a result the CAD software runs faster. We are running in native mode and if performance would be enhanced by Teamcenter that would be a powerful incentive to implement it.
I am using 7.5.2.5 NATIVE on Dell with windows XP OS
RE: Does teamcenter allow you to work locally?
In short, TC is 100% server based, does not copy anything to your C drive (unless you do it manually).
Best regards
Simon NX4.0.4.2 MP10 - TCEng 9.1.3.6.c - (NX7.5 native)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but by the number of times when it's taken away...
I know Windchill works this way with PDMLink, Intralink and Pro/E. I am pretty sure from what I have seen of TC that it also works this way.
Ben Loosli
The true files are in fact stored in a database (in a so-called "volume". These are database dependent). When a user beings to manipulate CAD files, the files in question are stored temporarily in a cache to prevent constant access to the files on the database. Once the user decides to save the file, the file saved on cache is re-sent to the server (the most basic explanation).
Depending on how the CAD administrator set up TC(E), the cache is cleared once the user has exited the program.
As a further note, it is possible to save files outside TC(E) by means of the NX manager.
I hope this helps!
Marc
NX Software Developer
We currently have about 5 users. We do not run Team Center but we do store all our part files and configuration files on the company server. We are small enough that we usually don't step on each other's toes.
Does your responce effectively mean that I should see a large increase in speed if we implement Team Center, as compared to what we are doing currently?
If you are working in native mode, there's nothing stopping you from checking this yourself: copy some files to your local machine and do some tests.
You will see a decrease in productivity because the users have more interaction with the PLM system that takes some of their time. There is overhead in doing file check-out, check-in and submitting jobs for the release cycle.
Once files have been checked-out of TC for you to use, you won't see any difference in opening or saving the files.
Ben Loosli
