Compatibility between versions of nx
Hi
Is it possible to work on .prt files created in nx 7.5 from with nx 6.0?
Must be an add on or something?
RE: Compatibility between versions of nx
There is NO downward compatiblity, period.
The best that you can do is to export the Solid/Surface model(s) via Parasolid and then open this file in the older version of NX.
To do this, go to...
File -> Export -> Parasolid...
...and select the appropriate version from the list of available ones.  Once the Parasolid file has been created, launch the older version of NX and go to...
File -> Open...
...and change the 'Files of type:' to the appropriate PS format and open the file and you'll have at least the Solid/Surface model intact (but with no history).
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
