Paralleling ct's of two circuits into one meter
My question is can I meter two three phase circuits with 200:5 cts. with one form 9S meter? Will these cts be additive.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Paralleling ct's of two circuits into one meter
Gunnar Englund
www.gke.org
David Castor
www.cvoes.com
Bill
"Why not the best?"
Jimmy Carter
(2B)+(2B)' ?
(2B)+(2B)' ?
I believe that the spec on metering class CTs is to maintain acceptable accuracy at rated burden and 200% current.
Saturation is an issue with protection class CTs. Acceptance testing includes checking saturation voltages to verify acceptable operation at anticipated fault current levels.
Bill
"Why not the best?"
Jimmy Carter
Metering class CTs are designed to saturate to protect the meter from high secondary currents in the event of a through-fault.
The more direct calc (instead of doubling impedance) would of course be:
Va = Ia * Za_unshared + (Ia + Ib) * Za_shared
Since Scotty mentioned protecting the meter, it brings to mind a question what kind of thermal limit the meter input has? (and could it be challenged?)
(2B)+(2B)' ?
