Try to delete line
Try to delete line
I have problems to delete a line from a model in NX5.
The line is not used, not in a group, not the last element. When looking at it with information/object there is nothing. What should I try?
RE: Try to delete line
Now adjust your selection criteria so that you can select all curve and point types. If the line is still there, try a show all move to see if it is part of something else.
If all else fails zoom out, use a box selection to select everything (check to make sure line was selected), then un-select the items you wish to keep and delete everything else.
File > utilities > part clean-up
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Can you upload it
Can you upload it?
That should have been my first guess - I totally forgot about that one.
