Centrifugal pumps: Viscosity and gas/liquid mixtures
How does viscosity affects a multistage centrifugal pumps ability to handle air/liquid mixtures. As viscosity increases, can the pump handle more air or less?
RE: Centrifugal pumps: Viscosity and gas/liquid mixtures
This is for air that is fully entrained within the pumped liquor and not free air entering the pump inlet from low suction levels or from other sources ie, slugs of air entering the inlet along with the product.
Assuming the viscous liquor contains air within the body of the product (the OP has stipulated air/liquid mixtures,not free air entrained at the inlet) - as it enters the impeller eye it may or may not expand depending on NPSHr/NPSHa, if there is an NPSHa margin over the NPSHr (there must be some difference in pressure at the impeller eye otherwise flow won't take place) the air will remain within the product and likewise we can assume that the air will remain at approximately the same volume. Once it fully enters the impeller the air will be gradually compressed (pressurised) as it flows thru' the impeller, this means that the "product" will reduce in apparent volume translating to a reduction of volumetric output performance.
However, if the air remains within the product, the pump will remained primed - which I guess is the main aim anyway and a pump that keeps pumping at whatever the overall hydraulic efficiency is, in my mind 100% efficient compared to a pump that is not pumping.
This may well be a bit of nonsense but it is the middle of the silly session and it might get some interesting comments anyway.
On another equally as interesting topic, when does wet dirt become mud?
When the water comes to the surface, due to shear forces acting on the mixture, thus dropping the coefficient of friction between wheels and/or shoe soles and the mud.
You can quote me on this, I spent a lot of time in mud as a youth, and that experience impelled me to get an engineering degree.
