Scale a block to fit a drawing
I have a very large block that I wish to insert into a B sized drawing. How do I go about scaling the block to fit the B sized drawing? When I try to insert the block I see the property manager gives me a scale box under parameters but I can't seem to scale the block regardless of the number I enter.
RE: Scale a block to fit a drawing
Are you able to post the block here for testing?
When I wish to scale parts for a drawing I enter a ratio. I'm not able to enter a ratio for blocks.
Input the ratio as Numerator/Denominator.
Example if you need a ratio of 1:2, then key in 1/2 and final value will be 0.5 (which means reduction in size by 50%).
I hope this make some sense and solves the need.
Deepak Gupta
SW 2010 SP4.0 & 2011 SP1.0
DriveWorks Pro 7 SP5
Boxer's SolidWorks™ Blog
Deepak,
It makes perfect sense.
You solved the need.
You're awesome!
Thanks!
