Bevel angle requirements
Hellow every one
What are the inspection requirements of pipe bevel angle? Basically my question is can we do grinding or perform filing on beveled/chamfered area when burr/chattering occurred during machining please let me know in the light of standard.
Jahanzeb
Jahanzeb
RE: Bevel angle requirements
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
Jahanzeb
What does the WPS allow for cleaning? Is the welding done to B31.3? API 1104? No matter which way you go, I bet that cleaning is a nonessential variable.
Cleaning the joint sounds like a reasonable request. Walk the inspector through the WPS showing him where cleaning is specified, and, if needed, where cleaning is either explicitly listed as a non-essential variable (Section IX, SMAW and GMAW at least) or omitted from the essential variables (API 1104, 5.4).
If the inspector won't yield, make a formal request for clarification requesting the chapter and verse of the applicable code that prohibits cleaning.
- Steve Perry
http://www.linkedin.com/in/stevenhperry
This post is designed to provide accurate and authoritative information in regard to the subject matter covered. It is offered with the understanding that the author is not engaged in rendering engineering or other professional service. If you need help, get help, and PAY FOR IT.
but i am still unaware of the actuall requirements
Jahanzeb
You need to read the applicable documents and determine the requirements that are relevant to your particular application. We have suggested a few standards and even given paragraphs within those standards.
Otherwise, I'm sure a hired consultant would be happy to help.
- Steve Perry
Assuming that you are the manufacturer, there is nothing in API 5L to prohibit you from touching up the bevels as you have indicated. If your repairs cause the ends to be out of square or the bevel to be out of tolerance per the Purchaser's requirements, the inspector would be correct.
