Speed reducer torque calculation
Dear colleagues,
I am a beginer in the field of mechanical engineering and i need to know what kind of gear i need to lift a 10 tons wheight if i use a 22 Kw / 750 rpm 8 pole electric motor.
The application consists in a electrical winch that pulls rail cars to a loading bunker with linear speed of 10 meters/minute.
The designer calculated that to pull a 700 tons wheight on railway we must use a 10 tons lifting capacity winch. The problem now is to find a speed reducer to do this job. Someone told me that i need a 63 ratio speed reducer but i think this is to small for this requirement. I attached the data sheet of the gear(3H-B-645 with the ratio of 63)
RE: Speed reducer torque calculation
Using 63 as GR the winch rpm is
750/63=12 RPM
With a winch dia of
10m/min/12RPM/Pi=.265m
The power delivered
20000lb*10m/min*3.3/33000=20HP
With an efficiency of 0.6, I get
20Hp/0.6*.746=25KW for the motor.
You will have to got to the mfrs to get the gearbox and motor effiencies.
So:
The motor has approx 290 Nm
63*290Nm = 18270 Nm
and i know that to lift 1 Kg of weight you need 10 Nm so i thought i need a torque of 100KNm to lift 10 tons but 18270 Nm < 100KNm ...
Use a 4-pole motor which is smaller, lighter, draws less current, has a better power factor and higher efficiency, and is easily replaceable from stock. 8-pole machines are quite unusual these days even though they are available.
Your motor must be sized for peak torque comprised of the following components:
(1) Torque required to spin up and accelerate the rotational inertias (gears, etc)to steady-state speed.
(2) Torque required to start moving and accelerate the translational inertias (load) to steady-state speed.
(3) Torque required to overcome gravity acting on load.
(4) Torque required to keep it all moving at steady-state speed.
Then you must also account for holding the load, either through brakes or other means.
Once you determine the peak torque, then you can apply efficiencies, safety factors, and "number of starts per hour" de-rating to get your max required torque and the motor frame size to accomodate the thermal requirements. THEN you can go look for a gearbox & motor combination.
And Scotty is correct: an 8-pole motor is a high-torque / low-speed oddball. 4-poles are "common".
If none of this Engineering Mechanics & Dynamics stuff makes any sense to you, then you should contact a gearmotor manufacturer's Applications Engineering Department or hire a consulting engineer to size it properly for you. ESPECIALLY if you are LIFTING a load.
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
No, Kg do not translate to torque, only to a force,Newtons, so
1kg is 9.8 Newtons and the output torque for 1Kg is the radius of the winch times 9.8. I got previously got .265 m for the winch so the 9.8 Newton force yields
9.8*.265/2=1.3 nM, so your calculation of 100Knm is reduced by the ratio
1.3/10
or
100Knm*.13=13Knm
And BTW, you do not start with the motor to get the gearbox, you start with the load and its linear speed and choose a winch diameter to get the output torque and speed of the GB and then work your way to get the motor and then to the gear ratio.
700t (weight to pull)* 0.03(coefficient for advancing the railway line)= 21 tons which you divides by 2 because we use a pulley at the opposite to the winch. The other factors are negligible because the railway line is straight and without inclination.
I chose the 8 pole motor because that is what the gear manufacturer said to use, it is a 22Kw 750 rpm with electromagnetic brake and i will start the motor with a frequency drive to avoid damage to the gear teeth by the starting inertia.
The question is whether this gear is capable to pull the weight if i use a 130 mm diameter drum to roll the cable. I have attached a hand sketch of 2 possible applications of the winch.
Tygerdawn can you help with some links for a online sizing programs.
