duplicating nearly identical drawings
In order to save time, is it possible to duplicate drawings but with a different "lookalike" part.
Example: I have 5 plates, dimensions 100x100, 200x200, 150x100, 150x150 and 250x250.
If I make one drawing of the first plate with all the dimensions on it, is it possible to duplicate this drawing and replace the first plate with the second one, etc..?
Jimmy
Jimmy
RE: duplicating nearly identical drawings
I'm using a master model. The client provides me the model of the total installation, I just have to make all the drawings of the model.
The installations are more or less the same, so I could save a lot of time if I could copy some of these drawings. Also sometimes they have a right and left part, but with only minor differences between the two.
Now I have to make these drawings twice, and I have to make sure that the second drawing looks the same as the first one (because that is less confusing for the people who will have to use the drawings).
I also work with Solidworks, and there you can open an existing drawing file, but make a reference to another part, I was hoping I could do the same with NX.
Jimmy
Then go to your palette, right click on the part/model referenced. There should be an option to replace referenced part. Select the model you wish to now reference. Save that reattach any floating dimensions, and save with a different file name.
Repeat as necessary
