Different configurations of the same part in an assembly at same time?
Is it possible to insert multiple instances of a part into an assembly and give each one a different configuration? Right now, when I change the configuration of 1 part it changes the rest of them.
RE: Different configurations of the same part in an assembly at same time?
Do you have a part pattern in the assembly.
Deepak Gupta
SW 2010 SP4.0 & 2011 SP1.0
DriveWorks Pro 7 SP5
Boxer's SolidWorks™ Blog
Deepak Gupta
Hardie "Crashj" Johnson
SW 2010 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
Deepak Gupta
So if you want to change the parent config, go ahead, then you have to change all your child part configs.
SW 2010 SP 4.0
