Help designing small snap-fit
We have a consumer product which needs a removable tip and we would like advice on the feasibility of a plastic snap-fit. The item is small and would require a "tubular" exterior shape (like the barrel of a pen). The outside diameter of the tubular snap-fit would only be .25 inch (by approx 1" long). First of all if it's feasible, what would be a guestimated pull-force limit for that size snap fit?
RE: Help designing small snap-fit
Segmented ring details get expensive fast, and are fragile.
So you have to cheat.
Your molder probably already has a favorite detail for this sort of thing. Most of them comprise some sort of 'bump' of simple geometry that deforms the mating cylindrical part, or its own substrate, or both, into a bilobular, trilobular or quadrilateral shape. So instead of expanding a circle uniformly, you deform it into an ellipse, or a hypocycloid or something like that.
Work with him; have him build a simplified aluminum tool at your expense to help him work out the exact details needed for your part.
Mike Halloran
Pembroke Pines, FL, USA
Here is one of tons of stuff on Google:
http://
Page 6 onwards, to save you doing too much work...
H
www.tynevalleyplastics.co.uk
Mike, do you consult outside the forum?
I'm in the book.
Mike Halloran
