Sketch in Drafting environment (Unigraphics)
Hello everybody!
Could someone explain me a good reason for creating a Sketch in Drafting environment(Unigraphics)?
Thanks a lot!
RE: Sketch in Drafting environment (Unigraphics)
Perhaps all you're doing is creating a 2D drawing.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
You can create a sticker on a bottle for example. This sticker can be fully parametric in the front view
Didier Psaltopoulos
http://www.psi-cad.com
. . . but if you did create a sticker, is there a way to not show all the dimensions?
I use it as John suggested. There are plenty of times when I want to make a simple print to communicate some information to someone on a different shift or to make notes for myself.
 It is also useful for creating geometry that is only needed in the context of drafting; stuff that you don't really want in the model. I'm thinking of situations where you are dimensioning a conical feature or an angled face and want to create the dimension "over rolls". The rolls aren't part of the model geometry so I just draw them in using the drafting sketch tool.
I have also used it to define areas that require special treatment of some kind. I'll sketch in the boundaries using a phantom line type and then hatch inside the sketched boundary.
I believe you can also use it for creating boundaries for broken out sections.
Not a feature I use every single day but the drafting module would feel very limiting to me without it.
-Jeff
Hi Jerry
You can hide some dimensions or suppress by expression
Didier Psaltopoulos
