Inverse definite time relay
What is a inverse definite time relay? How does it work?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Inverse definite time relay
Take a look at the ABB CO relay instruction manual. You can see how the relay works and the difference between the CO6 Definite time curves and the CO8 Inverse time curves.
http://www05.abb.com/global/scot/scot229.nsf/veritydisplay/913b92760e5ed74085256eac00564bc3/$file/41-103h.pdf
Inverse definite minimum time relay - a European term? Plenty hits on Google, although I doubt you will learn much if you understand how an 'inverse time relay' from your patch works.
Rafiq Bulsara
http://www.srengineersct.com
In other words if you have to ask that question, close the cabinet door and walk away slowly, then call someone who knows what they are doing...
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
(2B)+(2B)' ?
LPS.
"In this type of delay the latest practice is obtained by having the protective relay give a time delay which is inversely proportional to the magnitude of the overload up to about 1,000 per cent of load, but which becomes a definite time limit upon any greater overload than this."
Relays available from (it)micro, for example: http://www.itmikro.com/catalog/mk204a.pdf
Looks very much like an ordinary inverse time relay.
