ST3 Gesures...? Where.
Does anyone know where one can find some information with regards to "gestures" using the mouse.  I see my options are checked to use gestures, but where do I set these gestures, or discover them?
RE: ST3 Gesures...? Where.
The gestures relate to the inner ring of your Radial menu.  Rather than click-hold-wait-click to get the command on the Radial menu, you can right-click drag in the direction of the Radial Menu command very quickly.  Let go of the right mouse button and BAM! your command is active.  That's gestures.
--Scott
http://wertel.eng.pro
