Liquid Calcium Nitrate physical data
Hi
I am looking for Liquid Calcium Nitrate physical data, more specifically the density's and the viscosities at different temperatures. Does any one have a source which I could use, I have been searching for a few days now and all I could get is the data for solid Calcium Nitrate.
RE: Liquid Calcium Nitrate physical data
You might try some of the references sighted in this paper.
Plymouth Tube
That helped. Do you maybe know where I will be able to get the viscosity and density data at 58 degrees Celsius for the liquid calcium nitrate?
