How we will create dimensions in angle with X,y and z directions in NX
How we will create dimensions in angle with X,y and z directions in NX6?
AS an example,I have to create a dimension with an 10 deg angle.
RE: How we will create dimensions in angle with X,y and z directions in NX
What version of NX are you working?
Best regards,
Pascal,
NX5.04+TC2007 (GM Toolkit) / NX7.5 native
That should have been covered in basic training. It is also covered in the online help and the documentation that comes with NX.
Ben Loosli
Maybe they want to create a Parallel Dimension and having another measurement direction.
This is an enhancement in NX7 or NX7.5 (Not sure which version it applied)?
Grtz,
Best regards,
Pascal,
http://screencast.com/t/p9PtM4TZ3Gyd
Best regards
Simon NX4.0.4.2 MP10 - TCEng 9.1.3.6.c - (NX7.5 native)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but by the number of times when it's taken away...
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Best regards
www.jcb.com
The video answers my question.But can we do it in NX6?
Tony
In your drawing, 'Expand' the view which you wish to dimension and then under...
Format -> WCS -> Orient...
...set the type to 'X-Axis, Y-Axis' and which the selection scope set to 'Entire Assembly', select the 10 degree 'line' as the X-Axis. You can select anything else for the Y-Axis since only the first selection will determine the orientation. Once the WCS has been redefined, you can now use the normal 'Horizontal' dimension and select the two points of interest. Now unexpand the view and you should be good to go.
It should be obvious now why we enhanced NX 7.5 to allow you do redefine the 'dimension axis' on-the-fly as shown in my video.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Tony Paul
Karayamparambu
