Kt for filled theaded hole...
thread2-106068: Kt for filled hole
Referencing the above thread, I wanted to extent the discussion to not a net fit fastener, but to a standard or clearance fit preloaded fastener in a threaded hole.  What sentiment or knowlegde is out there for Kt's or Kf's for such a configuration.
Thanks.
RE: Kt for filled theaded hole...
that's odd ... this is the 2nd thread today on hte Kt of a threaded hole, and the 1st one has been deleted (RF'd?) ?
ream off the thread, and fill with an interference fit plug
Yea, I apologize for multi-posting.  I was just trying to reach a larger audience.
I concur that reaming and filling more soundly with an interference fit plug is more advantageous at reducing local stress magnitudes.
Regardless, I want to understand what knowledge exists on Kt's for standard or clearance fit preloaded fastener in a threaded hole...
Thanks.
Usually a threaded hole isn't good design practice.  As was stated, an open hole has a Kt of 3 and for a hole with a fastener, the Kt can go much higher (see Michael C.Y. Niu's books for stress at a loaded hole.  Such as "Airframe Structural Design").  A threaded hole would probably have an even higher Kt since there would be the combined effect of the hole and the additional stress riser of the threads.
Understood.  How about asking it this way - relatively speaking, what would be the difference in expected Kt for an open threaded hole in a thick plate seeing bending versus the same threaded hole filled with a preloaded clearance fit fastener (ignoring mean stress effects of fastener preload)?  I'm trying to discern whether there i merit to the possibility of 'filling' an open threaded hole with a preloaded net fit fastener and thereby extending fatigue life at that location.
Thanks.
