grid point force summation in PATRAN
Dear all,
Is it possible to obtain grid point force summation about a perticular node in local coordinate so as to get all the six quantities (3 forces & 3 moments),so that any perticular section can be checked for strength using classical methods.I tried in PAtran & got all zeros similar to GPFORCE balanace.
Thanks in advance.
Thanks in advance.
RE: grid point force summation in PATRAN
The classic example is to take a cut on a wing and get the resulting forces and moments.
Brian
www.espcomposites.com
Sorry ESPcomposites for the late repley.. net was down..
thanks for your suggestion.I tried with freebody tool and it really worked fine.As you have said we can also provide a summation point. Like i was trying for a T-sec & summation point can be the CG of the section.
thanks again
with regards,
shearlag
