Elastic Constants from PVC sheets
I'm a R&D engineer currently working on PVC sheets, that have been obtained by extrusion.
I have to find the elastics constants of this materials.
As it is anisotrope due to the fabrication process, I would like to do two tensile tests in the sheet plane, and a compression test in the perpendicular axis (sheet 3 mm thick).
Do I have to make shear tests ?
And what about the poisson's ratio ? Is there any way to measure it, other than by the lateral deformation ?
Thank you.
Thank you.
RE: Elastic Constants from PVC sheets
