what is the diffrence between orifices!
Hi all!
does any one can explain difference between swaged orifice, restriction orifice and line sized orifice!
RE: what is the diffrence between orifices!
The first one is an orifice with a tapered hole in the plate,
Restr. orifice is the common name and maybe someone else knows what a line sized orif. is?
hal1981,
Where have found these terms?
"We don't believe things because they are true, things are true because we believe them."
I've heard "line size" orifice, rightly or wrongly, refer to an RO without reducers before or after.
I.e. a 10" line reducing to 8" or 6" for the orifice run and orifice flanges would not be a "line size" orifice.
For a more official definition, I suggest checking Nayyar's Piping Handbook.
- Steve Perry
http://www.linkedin.com/in/stevenhperry
This post is designed to provide accurate and authoritative information in regard to the subject matter covered.  It is offered with the understanding that the author is not engaged in rendering engineering or other professional service.  If you need help, get help, and PAY FOR IT.
thanx
