ASTM A213 2007 edition - T22 mechanical properties?
I'm struggling to find where the mechanical property requirements (tensile, hardness, elongation) are for T22 material. Properties are listed for some of the other grades in the A213 standard however.
Is this intentional? If so, are there any adopted standards as far as mechanical properties are concerned?
RE: ASTM A213 2007 edition - T22 mechanical properties?
I should've read the standard a little more closely. 'All other low alloy grades' was listed at the bottom of the low alloy steels section in table 4 of the ASTM A213 (2007) standard, along with the mechanical properties I was after.
Plymouth Tube
