File path in acad 2000
HI can you help me?
I am trying to find a way to input file PATH in ACAD dwg.
(automaticaly)
Thanks in advice
ZMEI
(automaticaly)
Thanks in advice
ZMEI
RE: File path in acad 2000
The below VisualLISP code inserts a text object containing
the filename and filepath of the current drawing at the position 0,0 . Just follow the constructions.
1. Copy the below expressions and paste them into a text
file.
2. Save the file with the name FF.LSP .
3. Enter the AutoCAD environment and load the saved file
using the command "APPLOAD".
4. Enter FF at the command line.
(defun c:FF(/ acadObject acadDocument
documentPath documentName)
(vl-load-com)
(setq acadObject (vlax-get-acad-object))
(setq acadDocument (vla-get-ActiveDocument acadObject))
(setq documentPath (vla-get-Path acadDocument))
(setq documentName (vla-get-Name acadDocument))
(command "._TEXT" '(0 0) "" ""
(strcat documentPath "\\" documentName))
(princ)
Notice: If the current text style has a default height not equal to zero, the above program will interrupt and has no output.
If you want to run the program automatically every time you open a drawing, you can add the above code in file acaddoc.lsp (in the function s::startup).
In case of any doubt don't hesitate to be in touch with me using the present web page.
Farzad
Gordy
At the command propmt type in RTEXT and return, type D for deisel. When the dialog box pops up type in the following code.
$(getvar, "dwgprefix")$(getvar, "dwgname") $(edtime, 0, MONTH DD"," YYYY - HH:MMam/pm) Printed By: $(getvar, "loginname")
This should be all on one line. I place this in my border, it will update even if you do a save as.
I hope this helps.
