Points Drive Airfoil Profile?
Hi Everyone,
If I have a table full of points, is there a way to insert this in to NX Excel & have it create the airfoil profile? If so how?
RE: Points Drive Airfoil Profile?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
I found the info., but it's still not clear to me on how to set one one up.
I have point clouds at specified radial heights or I have an Excel table with X & Y positions.
Are there any examples to seeh how this works?
Thanks again...
John R. Baker, P.E.
Industry Sector
Cypress, CA
Insert -> Curve -> Spline...
...and select the 'Through Points' option. Then push the 'Points from File' button and select the attached file. This creates a curve which represents the bowl of a wine glass.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Thanks for the example.
I did create something from the DAT file & I guess it's in a bowl shape. However, it appears to more a a single line entity or spline or nothing like a wine glass.
Is this what it is suppose to be?
As for the table - How to put headers in the columns, without having file read them? Can this be table also be inserted into NX Excel to generate profiles?
Thanks again.
If your points represent airfoil sections, then you will need to create a .dat file for each section and use the technique I described above to convert the points into curves which can then be used to create the airfoil shape as a surface/solid model.
John R. Baker, P.E.
Industry Sector
Cypress, CA
