Sketch In Drawing?
Sketch In Drawing?
Sketch In Drawing?
Can I insert a sketch in a Solidworks drawing?
RE: Sketch In Drawing?
Yes, providing the sketch is in a format recognised by SW.
It's a Solidworks sketch. Do I need to save the Solidworks sketch as a .dxf and insert it that way?
You could, but just saving it as a block and inserting the block might be easier.
Or you could just copy and paste.
It depends on the function of the sketch.
Function of sketch is a shop floor layout with equipment, lights, air drops, electrical drops, etc. Each of these (equipment, lights, air drops, electrical drops, etc.) reside on a separate sketch.
Sounds like a good fit for blocks.
If you are just creating 2D layouts though, perhaps Dassault's DraftSight might be more fitting. 2D creation is arguably one of SWs weaker points.
Sounds good for blocks if you have put them in several drawings.
Create a common library and use them whenever you need. You can scale them during placement, keep them linked with original, rotate them after placement (in case you need a different orientation).
Deepak Gupta
SW 2010 SP4.0 & 2011 SP1.0
DriveWorks Pro 7 SP5
Boxer's SolidWorks™ Blog
