OHIP calculation with GOR
=(25000/379.4)/((25000/379.4)+((350*B11)/151.9)) This is a formula that I was given to calculate the fraction of gas given the GOR is 25000. Can you explain where the 379.4 and 350 and 151.9 come from?
RE: OHIP calculation with GOR
What units are you in?  Is this surface or reservoir numbers?
The units are 25000 scf/Bbl.  These are surface numbers.
What cell does B11 reference?  Is there a value in B11?
B11 is SG of oil
