General Table - Hard Return
I cannot execute a hard return in a solidworks general table to add a space. It closes the cell and go to the next available cell. I closed out of Solidworks and re-booted my computer. Both hard return on the keyboard and num pad doesn't work. I also tried creating a new SW doc and the same thing happens. See attached.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2010 SP 3.1
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
RE: General Table - Hard Return
This is the same as for creating multiple lines of text in the same cell in Excel as well.
-- MechEng2005
ArtL. I'm going to investigate the 3 lines of text you mentioned.
Thanks for your help
Mechanical Designer
Type your text into a text editor (notepad for instance), including the returns as you need them. Copy and paste the whole text into the desired location in SolidWorks.
Boy, I wish SW would make tables easier for both excel and the SW tables. None of the two are user friendly.
Mechanical Designer
[URL="http:// www.review belief.com /tv-video/ lg-32ld350 -32-inch-7 20p-60-hz- lcd-hdtv-r eview.html"]lg 32ld350 review[/URL]
In Excel it's always been [Alt]+[Enter] to get a carriage return in a string of text and I've never seen that fail in either Excel or a SolidWorks design table.
Just to be certain macduff I looked at the image you attached and recreated it in both Excel and through a SolidWorks design table. Then I repreated it several times in a cell. The only limitation I could find was in row height. Mine maxed at 409.5 (this is Excel 2010).
Jack Lapham
Engr Sys Admin
Dell M6400 Covet (24 Season 8, Ep 22)
Intel Core 2 Duo T9800, 2.93GHz, 1066MHZ 6M L2 Cache
8.0GB, DDR3-1066 SDRAM, 2 DIMM
1Gb nVIDIA Quadro FX 3700M (8.17.12.5896)
W7x64 | sw-01: 55.92
SolidWorks x64sp4 in PDMWxE
