Automatic Assembly Configuration
I have different sized cabinets that I would like to assemble in Pro/e.  I have created a small assembly in Pro/e with the cabinets arranged as I would like, and I am able to EDIT DESIGN within my Pro/e program and modify the code for this assembly to show the cabinets in a different order than my original assembly.  However, I want to be able to do this from user input (selecting which parts to add and in which order). Instead of modifying an existing assembly (where the Internal Component IDs are known), is it possible to write code within Pro/e to take part names as input without having this component ID that I believe is assigned in the assembly?
 ADD PART A4_H2_STANDARD
 INTERNAL COMPONENT ID 47
 END ADD
 ADD PART B1_H2_STANDARD
 INTERNAL COMPONENT ID 50
 PARENTS = 47(#5)
 END ADD
 ADD PART B2_H2_STANDARD
 INTERNAL COMPONENT ID 52
 PARENTS = 50(#6)
 END ADD
Thanks!
