High Pressure Electric Boiler
We are looking out for an electric bolier (for R&D Lab) with following specifications:
Steam flow - 300 Kg/hr
Pressure - 100 Barg max
Can you pls help me with information on boiler manufacturers?
Thanks in advance.
RE: High Pressure Electric Boiler
Thanks steamdog for your reply. I checked sussmanboiler website but it seems they make electric boilers upto max pressure of 150 psig only whereas our requirement is 1450 psig.
Sorry Pingmi, I read 100 Bar and was thinking 10 Bar...  They do make one line that goes up to 250 psig, not nearly enough for you....
try generalboiler.com  pressures to 150 Barg
I haven't seen or heard of an electric boiler with your required capacity. Your required capacity is quite small for the equipment that would be required to produce it. I believe that the only way you achieve the require pressure and temperature would be to use a cylindrical monotube and molten salt as a transfer media.
One Steam Jenny a cylindrical monotube  is capable of 450 psig of saturated steam. I have worked with these but all were fuel fired. There was a small cylindrical monotube boiler on a (?Noble Steam Car?) that operated at 750 psig
unclesyd, it is the same as a big boiler at the same pressure.
electric resistance element steam boilers/steam generators are common
at any pressure, it is expensive to build because takes the same controls as a large steam. generator.
for gas/fuel steamers, the same process, can be built as water tube.
We take orders form 2pph  steam generators at 2500psi of course we give the customer 10 pph min. instead as it cost us the same and we feel bad to get paid for so little steam. current order of 2pph at 500psi. pc of cake.
