Reorder sheets in NX6 drafting
Can we reorder drawing sheets in NX6 drafting.Examle.
If I have two sheets in the drawing sheet01 and sheet02,can I reorder sheet02 1st and sheet 02 second in NX drafting
RE: Reorder sheets in NX6 drafting
You can reorder the sheets, however, if you use the system parameter on your formats, they will still be sheet 02, then sheet 01.
The work around is to take the sheet 01 data to a new sheet 03, then delete the original sheet 01.
Ben Loosli
Please let me know how to reorder(procedure in NX6).
