select an item and then launch a macro
Hello everyone.
How can I get a macro to work with an item previously
clicked (in particular, I'm talking about a dimension in a
design)?
My problem is to find a command that can recognize an item if is highlighted or not and then use it in macro.
RE: select an item and then launch a macro
in the macro get the selection object of the document. you might also want to use selectelement2 (single selection) or SelectElement3 (multiple selections) in the macro to allow users to select a dimension if on is not already selected
Read the API documentation for these calls. and be careful of earlybinding / strong typing the selection object if you are going to use any of the calls that require an array of variant strings.
Very roughly something like the following (not tested)
Dim oDoc
Dim oSel
Dim vaFilter(0)
Dim sRet
Dim oObject
Set oDoc = CATIA.activeDocument
Set oSel = oDoc.Selection
vaFilter(0) = "DrawingDimension" 'not sure if this is the correct type name for a dimension object
 sRet = oSel.SelectElement2(vaFilter,"Select Dimension", true) 'the true here allows preselection
if sRet = "Normal" then
  set oObject = oSel.item(1).value
else
  msgbox "Selection canceled"
end if
Thanks Peter your solution works very good!
Now i've another problem: i use this routine to create
labels(drawingtexts) associated to dimensions, and so i need create a similar routine for eliminate these texts.
The only way that i've found at the moment is to use
"drawingtexts.remove(0)" but is very difficult to use it coupled with the routine above.
Any idea?
oSel.delete will remove every thing in the selection
Ouch!! i'm stupid!!
Thanks again Peter
